Pleeeeeeeeeeeease can someone help me with my plite with this vizo boiler i have had fitted. Worked for 2 months and now no heating downstairs. Heatline replaced pump still no joy. Had system flushed radiators taken off etc etc. Why doesnt it work
By your post i take it all your upstairs rads work and its only downstairs not heating
If so your boilers working but not circulating TRY turning off all upstairs rads and see if the pump pushes heat downstains..
To clear air lock
Its worrying that Heatline replaced the pump under the warrantee when the pump was not at fault!
Heatline is now owned by Vaillant!
Is this yet another example of Heatcall failing to diagnose the problem?
Let us know the result of turning off the upstairs rads. If that makes it work then see the FAQ on this site for balancing rads.
Now was the system power flushed? Did the Heatline man comment on the condition of the water?
Tony
Agile";p="972504 said:I am sorry that I am so far away as I love to solve problems which others have failed to.
If you are in the North then I could ask my ex-trainee to have a look but unfortunately he is very helpful but not that good.
Can you take off a DS rad and open each valve in turn into a bucket and see if you get a good flow?
Basic question! Is it microbore or standard 15 mm tube?
Another question! Did the system work OK before the boiler was replaced?
To
Thanks for trying I AM TOTALLY no expert. I might have to take degree. Just so frustrated the boiler was a worcester combi before which was over 12 years old and we were replacing this and that so decided to have a new combi. Had this heatline vizo fitted which worked for 2mths then nothing. Since then all these experts saying all sorts. We live in a victorian house 100 years and they mention valves......... Where to look though cos no one is giving any indiacations. British gas i am looking to next. Where are the experts in the plumbing line as you are so far away???? I need a good guy???
melneedshelp";p="972549 said:I am sorry that I am so far away as I love to solve problems which others have failed to.
And the boiler was ok before it went awol. Always had heating downstairs. New one fitted all ok for 2mths then overnight nothing as in heat downstairs
To
