- Joined
- 3 Apr 2010
- Messages
- 15
- Reaction score
- 0
- Country
Got a problem with my Heatline Capriz 25 Combi boiler.
My heating started to go a week ago. The boiler would fire up but not continually so the water would never get to temperature and my boiler would be constantly firing up. I put more water into the system upto 2bar and bled a radiator to take it back down to 1.5 bar and this somehow resolved the problem...
Until yesterday, It fired up in the moring on timer, but when it went off I flcked the timer onto continuous and nothing happened!
No LEDS on, nothing.
I opened it up got to the circuit board and both 2Amp fuses were blown.
I replaced them, and it worked again!
But only for 15 mins when I turned it on and off at the plug the LEDs came on but didnt fire. I thought it was an issue with the timer so fiddled with that and i accidentally crossed wires on the timer terminals. (red 1 and white 3). This caused a small spark and No LEDS nothing again!
Bought a new PCB, put that in 1 hour ago. It fired up! LEDS all on.
5 mins later the 3Amp fuse in the plug blew!
Now I'm thinking its an issue with either the Pump or Gas Valve?? Does this sound like it could be?
I'm currently in the process of takinig the pump apartand seeing if that has got blcoked and is over loading the cirucit? Or if its not earthing...
Any help would be greatly apprecieated..
btw taking the pump apart, do i need to drain the system or turn off the water supply??
Just replaced my PCB as there were no LED's lighting up at all.
