I have already replaced the pump and the 2amp fuses still blow.
Installed boiler myself 2 seasons ago as we live on a "houseboat" and the local engineers with marine tickets won't get out of bed for less than £200.
It ran ok except that we only got hot water on the Winter setting (CH +DHW).
So, new pump, all runs fine for 5-10 mins, rads get hot, then fuses go again.
Try again, new fuses, switched on at mains, but boiler controls OFF. Sparking noise from LH side of pcb but nothing visible - behind the adjustment potentiometers. Fuses blow again after 1-2 minutes.
The fault-finding chart is not clear. Do I replace the pcb or the interface card? I don't want to make another expensive guess!
