I've got a new build house which we moved into a few months back. After using the heating system for the previous few nights I'd noticed the top floor radiator was in need of bleeding. Unfortunately due to the massive amount of air that was released (did all of them to check and a fair bit came out!) the system pressure has now dropped below the minimum and the warning light is flashing.
I've spent the past 40 minutes under kitchen cupboards, pulling stuff out and looking under the boiler but I can't see which one is the pipe I need. Could someone confirm which of the pipes is the filling loop for me so I can attempt to follow it and find the valve? Its a Heatline C28 which we have all the installation certificates for but no manual and the heatline website is completely useless.
I've read the FAQ and understand what I need to do but simply can't find the correct valve. I have a horrible feeling the builders have built the kitchen cabinets over the pipes and not cut a hole to access the valve
Any reply would be greatfully received as the missus is dying for a bath after a long day at work and the builder isn't answering for us to 'claim' on the house certificate (for an all be it relatively simple job)
