I have a Heatline S30 Compact which was fitted in 2004. The diverter valve spindle is leaking through to the motor and blowing the fuses. I have purchased a repair kit 3003202082 but the black nut supplied in the kit is different to the original. The head on the slotted nut in the kit is 13mm deep whereas the original is approx 8mm.
When fitted and the motor refitted the control unit will not close since it now fouls on the motor itself.
Is this the right kit? The Heatline technical advice line suggested that there has only ever been one type of nut so it must be that I had fitted incorrectly. I have both nuts in front of me and they are clearly different.
I have had this problem before in 2009 but back then I resolved the problem by swapping the seals in the nuts over. I am reluctant to do this again since I feel that they may not have seated correctly leading to the problem reoccuring 14 months later.
Any help or advice would be greatly appreciated.
