Heatline Star 24 Boiler problem!!!
16 Jun 2011
West Midlands
Hi, I have a Heatline Star 24 Boiler which fires up on hot water and heating, but then goes off after 5-10 seconds. I have already changed the flame sensing electrode and the lead changed but the problem is still the same. An Engineer has suggested the Ignition PCB which is on the gas valve.
Any help/advice would be appreciated. Thanks.
Doubt it's a pcb get a rgi that can fault find correctly, nobody here will answer your question as it's gassafe related and if you have changed part in the chamber you will be willing to have a go at anything! Have you even had somebody out to look at it? Or are you going around the house trying to DIY it?
best advice, stop being tight and get some one qualified to work on boilers to fix it for you. Do you carry out the usual checks that an RGI would when replacing the components?
