Hello
I have just moved into a flat that has a Heatline Vizo 24 combi boiler.
As soon as I tried to turn it on, it didn't start. The BAR light kept flashing because the pressure was below 1bar. I repressurised it manually and put it on timer to turn it off during the night and on again in the morning. For the first two days it worked, but then again, one night, the pressure dropped below 1bar and the boiler didn't start.
Does this mean that there is a leakage somewhere? I don't understand why sometimes it keeps working and sometimes not.
Another strange thing is that, when on, the pump (I assume is a pump or a fan...) goes on and off continuously every 10 seconds and it's extremely noisy. The boiler is not inside a cabinet or anything, just in the middle of the kitchen, so this worsens the noise in the flat.
Is this noise the normal operation or am I using the wrong settings or another sign of a problem?
Thank you.
Thank you.
