Hi All,
Posted on here once before and got a great answer first time round, so relying on you guys once again!
DHW is going hot and cold. When there is hot water demand, boiler fires up and gives boiling hot water, then after 20 secs the boiler flame cuts out with a click and then reignites about 15 seconds later. This process repeats itself resulting in the hot and cold water. Plate heat exchanger was sludged (removed through back of boiler by removing dhw outlet feed) and has been flushed clean but think I will clean with spirit of salt next.
Question is: is this a sludged heat exchanger issue causing the flame to go out each time as above? Or something else like a sensor? All help appreciated.
Thanks in advance as always.
Jack
Jack
