Heatmiser wireless thermostat
25 Feb 2012
Manchester
I've just bought a Heatmiser PRT-WTS wireless thermostat and was wondering how I wire the reciever part (RC1-WTS) to my Saunier Duval SD 30e combi boiler?
Manual for the reciever http://www.heatmiser.co.uk/web/index.php/docs/finish/32-english/61-heatmiser-prt-wts-manual p7
Manual for the boiler http://www.ultimatehandyman.org/PDF...uval-SD-30E-Installation-manual-47-920-16.pdf p20-21
On the reciever I have L, N, COM and NO1 and the boiler L, N, E, R1 and R2
Obviously I wire the L and N to the reciever but what do I do with the relay part? Looking at the boiler wiring I would assume I link the L and COM on the reciever and wire from NO1 to R2, is that correct?
Cheers
Andy
Are you replacing an existing stat and/ or internal time clock?
In it's basic for I would wire L & N from boiler spur to receiver and R1 to COM, R2 to NO1.
There isn't an existing stat just an integral clock. On p21 of the boiler manual I read it as the 230v room stat, No frost stat option given the reciever is 230v.
The link to the programmer still does not work.
Do you have 'volt free' connections on the programmer?
If so, just connect them to R1 and R2 after removing the link between R1 and R2.
Bottom left diagram on page 21 of boiler manual.
You will then have to set the boiler's integral clock to permanently on.
I cannot find a wiring diagram with only the terminals you mention.
Do you have the instructions?
If so can you scan it and post it?
I know what I think it should be but am hesitant to say without seeing the correct diagram.
In that case do what Sherbertlion said above.
L - L
N - N
Plus Earth
Remove link between R1 & R2
Com - R1
NO1 - R2
DO NOT link L - Com
Edit - posted before I saw Holmslaw's post.
Can see the diagram now.
