Hello,
I need to replace the function selector switch for my Samsung oven. Where it's failed, it has also charred some of the insulation off one of the wires connected to it. So I'd like to insulate that section of cable. I have plenty of 'bog standard' insulating tape, but am worried that the heat in the oven might damage it. The area should not get VERY hot - it's outside of the main oven cavity, just behind the fascia. But the wire might also get hot just from its own resistance - something obviously caused the switch/wire to overheat before.
I've seen "PVC Insulating Tape Black 19mm 20metres Electrical Insulation (Flame Retardant)" available - would this do the job? Or is it flame retardant in an intumescent kind of way, without any real heat-proofing? Or should I go for something else? All the wires are all just normal plastic-insulated, not that braided fabric type that you sometimes see in hot areas.
I've just had a look at the spec of bog-standard PVC tape, and Screwfix claims it "Works at Temperatures up to 80°C", and is "Flame retardant and self-extinguishing." So I guess the bog-standard stuff IS flame retardant, but not heat proof, as I suspected.
Thanks in advance for any help!
