Hi guys,
I've got a Heatrae Sadia C600 and a new Honeywell CM907 controller in my flat and I need to know what settings I should program in the installer setup menu on the controller, especially with regards to "Cycle Time/Hour" and "Minimum On Time".
I noticed the Heatrae takes 3 minutes to fire from the point of activation by the controller (Call flashing for 3 minutes, then the boiler kicks in)
Does that mean the minimum on time needs to be above 3 minutes? Possible values are between 1 and 5, 1 being the default.
What should the cycle time per hour be set to? Values are 3, 6, 9 and 12, 12 being the default.
Thanks for any help with this!
