I have a Megaflo hot water cylinder in my flat, it has two immersion elements the upper is connected to a boost switch and the lower into a fused wall switch.
Question 1:
I am wondering, having read other Megaflo threads on this forum why the flats in my building do not have Economy 7 meters. We do not have a gas supply so electric water Heating is the only option. Is it usual for an electric only water heater to be connected to non Economy 7 and in effect be switched on all the time maintaining a full cylinder of hot water 24/7 via the thermostat?
It seems like bad planning on the part of the builders but is this in fact normal? Electricity usage seems quite high, so at the very least I'd have expected a timer device instead of just an on/off wall switch.
Question 2:
The lower thermostat I believe has failed, I can only get hot water via the boost button and this provides just enough hot water (the top half of the tank) to have a shower. I've put off sorting it for a while but now want to get it sorted so there is at least the option of running a bath.
I have identified the thermostat as the problem, somehow it has overheated and melted the wire insulation onto the terminals causing it to break the connection. Having stripped back the wires and cleaned up the thermostat terminals I cautiously observed what happened upon reconnection - it did heat water but the thermostat housing became hot to touch (more so than the boost thermostat after a similar time switched on from cold). So I shut it off again and have been using only boost since.
I know people on here will often say get a G3 qualified person in, but I am competent in wiring so once disconnected does the thermostat just pull out, or is there more to it?
Do I need to drain the cylinder first?
I have seen the Cotherm TSE is around £44 so will order online if it's a simple pull out and re-wire job?
Thanks.
Question 1:
Question 2:
Thanks.
