We have an oil fired worcester heatslave 12/14 with a built in timeclock. Since yeasterday we have had no heat or hot water. The thing won't even fire up when a hot tap is turned on, we have tried calling for heat/hot water on the timeclock both together and individually, the red lights light up but nowt happens. There is power to the boiler and timeclock but no pump spinning burner movement or infact any noise except for the hot water flow switch that clicks when a tap is turned on. I have looked for lock out buttons but none have tripped and the lock out light has not lit. PCB??? Time clock??? or could it be something completely different???
Any clues, I need a hot shower, getting a little whiffy around here
You help is greatly appreciated
