The hot water supply from the boiler seems to be erratic. Boiling hot for a short time then like warm then hot then stone cold then luke warm.
I have recently replaced the diverter valve.
The heating works perfectly
The pressure in the boiler is fine
The cold feed pressure to the boiler is fine
The 3 bleed valves on top have been bled.
I can hear the flow switch click when I demand hot water but it doesn't always fire up right away,
My guess is the dhw thermostat.
But is it a possibility that it could be the flow switch?
Any help would be much appreciated.
Thanks.
Thanks.
