I have a heatslave 12/14 combi oil boiler. If i installed a solar panel with a pre-heat tank can I pass mains water through the tank via a coil in the tank and then on to the heat exchanger in the combi to re-heat or not (depending upon inlet temperature) the water. Can the DHW flow valve work with hotter water? and can the plate heat exchanger cope with hot water on its cold side?
Any advice would be helpful.
