Heavy radiator - am I being over cautious?
25 Oct 2014
Berkshire
I am planning to replace a single radiator with a new double one in a bay window in an upstairs bedroom . The new radiator weighs around 55kg including the water. Dimensions are 450mm x 1600m.
The wall is plasterboard and I have found 2 vertical studs and luckily they are in the correct location to attach both brackets to. My only worry is how well those vertical studs were screwed into the sill plate. Should I cut away some plasterboard and investigate further or just crack on?
Cheers!
