Hello all, I was directed to this forum as I heard you might be able to help me.
I removed some old 70s plywood boards from my kitchen walls and would like to fix plasterboard up for tiling and painting. There are existing battens but they are only 20mm thick, from the wall. Would these battens be sufficient or do I need to replace them with thicker CLS. The spacing is more or less correct on these so it would be easier to leave them in place.
Can sockets just be fixed to the battens so they'll come out of the plasterboard, without having to use a plasterboard pattress?
One wall is an external wall, there's no problems with damp at all, but do I need to use plasterboard with a vapour barrier?
Thanks for any help
Thanks for any help
