Hi
I hope someone can help.
I have been given planning permission to erect a wooden garden office in my garden on the foundations of my old garage.
Once erected the first job will be to install the electrics. I had planned to do this myself, but are not if I am now able to do that legally under the new regulations.
My plan was/is as follows:
The garden office will be 1m from the back of our kitchen. The kitchen has its own 32a ring main with 5 double sockets powering the following regularly used:
1 * 500mm Fridge
1 * 500mm Freezer
1 * kettle
1 * 500mm dishwasher
1 * Gas heating control system
I assume that this level of load is small compared to the ring main capacity. I can access the ring and it was my intention to break-in properly extend it out into my garden office by taking it out of the kitchen wall, along the side of the house for 1.5m with the 2.5 T&E in a protected PVC conduit to a 1m pipe buried under garden paving to the garden office.
I then planned to include in the office part of the ring
* Two double sockets for a TV, PC and music centre
* A fused spur to power a 2kv convector heater
*A fused spur for two banks of 3 low voltage lights.
* A RCB protected spur into garden shed next door (both will be butted up to each other and power cable under cover at all times) to power a small pond pump, a UVF filter, 100w ceiling light for the shed, an external security light and a Freezer.
Any comments would be appreciated, in particular:
1. Am I allowed under current regulations to extend the ring out of the kitchen in protected conduit as described or will I need to get an electrician
2. In the case of the shed, would it be better to simply extend the ring to include the shed as well or is the RCB protected spur approach OK?
Whilst I have added spurs in the past, I have never really done any external building wiring and welcome any comments people are kind enough to make.
Gerry
1 * 500mm Fridge
1 * 500mm Freezer
1 * kettle
Gerry
