Hi
I've found a real bugger of a job.
I installed a new shower onto existing pipework from the old shower. The customer wanted a pump but didn't want me to redo all the pipework so that the shower had independent supplies so she decided on a Salamander RHP whole house pump.
I installed this in the airing cupboard along with a Surrey flange. A few days later I had a call saying that the pump was "revving". On investigating I found the pump was sometimes activating & deactivating in quick succession sounding like "revving". I put this down to air in the pipework that was triggering it, then because the taps were closed was deactivating.
I then installed an AAV in the loft on the highest point of the hot supply pipework. I also put one on the highest point on the cold, after the pump as it goes back up into the loft and over to the bathroom from above.
I then had a call again saying it was still "revving". After talking to Salamander I was recommended to fit a single check valve after each pump outlet. I did this and it cured the revving.
However, now the hot taps still get air in them but because of the check valves it can't escape. So, when the hot taps are turned on it take about 10secs before any water comes out and the pump kicks in. Opening the cold tap makes the hot work immediately but obviously isn't ideal.
The hot outlet from the pump seems to dissapear under the floor under the airing cupboard rather than going up into the loft - so I'm confused as to why it's locking ?
Any suggestions anyone????
much appreciated,
Graham
much appreciated,
Graham
