Hi all.
I went to do my normal bleed and top up routine yesterday- ready for winter,and found my pressure gauge at zero. Anyway,a bit worried....I top up to just over 1bar....and turned on full...all radiators open,ready to bleed. It was then I noticed the pressure raising to 3 bar and over...checked outside prv outlet and indeed it was weeping water. I shut the system down and cooled ( pressure now on about half bar ). Checked expansion vessel schrader valve to see if any water was present - and it was dry, however there was no air in there what so ever. I drained more water from the system to zero....then tried recharging with my bike pump - but there was no way I was getting air in there. Today I purchased a new schrader valve core and replaced...before doing so,gently poking around the schrader hole,which seemed to give a little,with a tiny hiss...and got a bit of crap out . So fitted new schrader core and proceeded to recharge. I’ve got to 1bar...but noticed the water pressure was matching it...also at 1 bar. I’ve bleed a radiator again to get down to zero pressure water side ...and the air pressure in the EV also dropped to zero!....tried once more - bleeding - zero water - repressurize the EV...again both pressures have gone to 1 bar. I’ve stopped now as don’t want to drain anymore water without advice. Please any advice...is it normal for both pressures to rise until I get to a point where the bellow inside is more than the water pressure ( ie did I originally over fill with water...which is sitting in the EV
