Help Bleeding Radiators
7 Aug 2007
Hi, I have a few rads with air in them. Problem is the bleeder valves are rounded off and can't be opened. Is there anyway of bleeding the system without me having to replace the rads in question. As far as I know I have a normal oil back burner system.
Any help would be greatly appreciated
how do I do that because I can't get a grip on them
if its the bleed valves that are tapped directly into the radiator, you either drill them out or replace the rad.
oh ok, not what I wanted to hear. Thanks for the the help
hopefully you should be able to remove the whole valve rather than just the screws and replace them, all depends on what type of rads you have.
If you have the other type of rads ill have to have a think about it.
Im sure someone else will answer in the meantime with an easy way
