Help! Bosch Classixx 1200 loud banging and rocking on spin?
18 Feb 2010
Kent
Can anyone help please.
My Bosch Classixx 1200 (about 5/6 yrs old)
has started spinning with extremely loud banging and rocking. Does this sound like something that can be repaired easily and cheaply? :p
Thanks to all who respond. Elizabeth. :p
Hmmm....afraid it doesn't sound hopeful.
Open the door & try lifting the drum up & down to see if there is much slack. Then spin the drum by hand & listen for a grumbling mechanical noise. If you find either an economical repair is highly unlikely. There could be other causes...a loose balance weight or maybe a bust shock absorber. But frankly it doesn't sound too good either way.
Doesn't sound to good I thought mine was on the way out but found a bra wire had gone through one of the holes in the drum and was throwing it out of kilter,good pair of grips and a good heave ho and it solved the prob.
loose top springs or tired suspension legs.
sounds like its had above its 5-6kg max load
