Help, Broken Tile & Stained Grout!
19 Oct 2008
Hertfordshire
It appears that something heavy has been dropped on my kitchen floor, although must have been a ghost as the wife and kids deny all knowledge of anything happening!
Anyway there is now a hole of about a 10mm in diameter in the middle of one of the tiles, and when I tap it, it sounds hollow. I assume this will need removing (rather than simply filing the hole). Does anybody know how can I cut this tile out without damaging others?
Another issue I have is that the light grey grout I have used is now very stained after only 6 months or so , is there a simple way of cleaning it or do I need to rake it out and re grout? Once I've cleaned it or regrouted is there a sealer I can use to stop this happening again?
Thanks,
Dan
You will need to rake out the grout round the tile then hit it with a hammer to break it,you should then be able to lever the pieces out.
To clean your grout use a bit of bleach and an old toothbrush.
You can get grout sealers but don't know if they make much difference.
Thanks for the response Lancenotalot.
I'll have a go at it at the weekend, bleach sounds alot easier than raking out the grout & regrouting!!
Dan
