Hi all,
I would like to create a concrete base in the garden - as part of this, I have had to dig up a lot of existing re-inforced concrete (from a WW2 bomb shelter) which I would like to use in the base (rather than getting rid of it, which will be a nightmare).
As a result, I have dug a hole which is about 45cm deep. In order to accomodate all of the rubble from the bomb shelter, I have built shuttering which also extends about 30cm above the ground.
I know the depth is overkill, but it means I can avoid having to shift the rubble.
Here come the questions:
Can I just break up the concrete into small pieces (say the size of 2 pint glasses) and place in the hole, before pouring concrete in and levelling?
Do I need to have a subbase, or will it be ok if I have small pieces (as described above) before pouring the concrete.
What about any membranes (dampproof or weed proof).
The dimensions of the area to be filled with concrete are: 2.5m x 6m).
Any help appreciated.
