Hi
I need to investigate a blocked drain to see if I can resolve it myself before resorting to calling in a pro, but I can't lift the recessed cover in my garden. I can access the lifting keys no problem, but it won't budge. Two of us have tried lifting and the weight (even with slabs inset) should be quite manageable.
I am assuming that possibly some sand/cement mix or other debris has bonded the tray to the rubber seal. I have tried to seperate the seal by running a fine blade right around the edge, have tapped vigorously all over with a rubber mallet to to try and loosed things up and nothing seems to be working. My next thought is to resort to getting the angle grinder out and cutting the slabs in the tray so I can lever them out.
Anyone have any ideas/advice. I am concerned at damaging the tray/seal and want to avoid shelling out on hiring a hydraulic lifter.
Alp
Alp
