Help! Can't screw the anchor bolts into plasterboard! :(
23 Mar 2014
London
Hello everybody,
This is my first time experimenting with DIY. I've been trying to mount my projector onto the ceiling. I got those hollow wall anchor bolts (10mm diameter) and just can't get them to work. The first one wouldn't secure and the second one just made a huge hole and fell above the ceiling. I've followed the exact instructions and made sure the little teeth on the anchor bolts were secured in the plasterboard. What am I doing wrong here? :confused: I've attached pictures just in case.
Many thanks!!! Appreciate your help!
//www.diynot.com/network/PaulJunior92/albums/
Even with the fixings properly in place I would not think it ideal to have the projector fixed to plasterboard. Either fix it to a joist or put a noggin in.
You definitely need the setting tool for those fixings.
When I last had to do this I painted a piece of MDF to match the ceiling and screwed it to the joists, then mounted the projector bracket to that. I would never trust it to plasterboard alone, no matter what the fixing was. Even if it holds up now if there is ever any damp in that ceiling (including 'leaky' rodents) that fixing will eventually fail.
