I have a 3 bed house with 1 bathroom and I know that the mains cold water pressure is 3 bar. Part at the build work is to install a shower which requires 2 bar pressure.
The plumber my builder has just sacked, as he had no confidence in his work, stated that I needed to keep the hot water tank and add a pump. However, I have found the following boiler Worcester Condensing Combi Gas Boiler Greenstar 35CDi, and the spec's say that it delivers hot water at the same pressure as the incoming cold.
So the question is do I still need to keep the hot water tank and add a pump or will the new boiler do the job on it's own?
Obviously my builder is going to get a registered and qualified plumber to do the installation.
Any advice welcome.
Cheers, Mike
Any advice welcome.
Cheers, Mike
