Hi everyone,
We have been renting for some time and how just found out that we are able to buy the ground floor flat we live in..
We are wanting to put down lighters in, but have concrete ceilings. We are happy to put a false ceiling up (wooden battens or metal frame + plasterboard), however when I heard someone that we might need to put in fire rated down lighters because we are in the lower flat, but this means the height reduction from the ceiling will need to be almost 6 inches!, rather than just 3. Does any one know if we do need fire rated??? I looked up building regs online, but couldn't find much/anything, other than timings for how long a floor should withstand fire.. but as ours in concrete it should be pretty good so surely we dont need fire rated fittings do we???
Thank you in advance for any help!
PS..!!>> Just to throw another option in. We were going to use LED lamps instead of the standard or we can even just fit LED fittings.. any way to get downlighters... but i just want to make sure i know what options there are as I would prefer (for cost).. non-led fittings, non-fire rated, with LED lamps.
Thanks.
Thanks.
