Ok guys I have to solder a solder ring onto a downstairs toilet hot water pipe. I currently have a push fit plastic connector inplace but I was told by my plumber a solder joint would be better. The pipe join will be concealed behind plasterboard.
I have attached a photo of my water tank that I was told needed to be drained. First the cold main feed to house was to be isolated. Then the hot water tank. But as you can see their are a number of red gate valves that surely a couple isolated would all that would be needed?
Possibly keeping the hot water but isolating it from the pipes I need to work on. I tried it before and had a drip drip all the time and even tried bread so I could work on the solder. In the end I put a push fit connector on. Maybe I need to give it more time to stop dripping? Ok looking at the attached photo which gate valves do I need to isolate?
Any help will be gratefully appreciated
