Help - faulty wiring on room thermostat ?
11 Jan 2005
I've been having a problem in my fathers new flat. The room thermostat doesn't operate the central heating. The heating, once on, stays on permanently. On measuring the red live and yellow switched live on the stat itself, they are both live whenever the central heating is switched on by the timer. When I continuity checked the wiring I found red and yellow wires short circuit. When I disconnect them from the junction box in the airing cupboard, they still read short. So I can only assume the wiring is damaged somewhere. But before I start to make holes in the walls and ceiling to replace the cable, I'd like an opinion to see if I'm missing something. I'm pretty sure I checked the wiring correctly i.e. the red live at the stat goes to the switched live from the timer, and the switched live from the stat (yellow) appears to go to the CH valve. Please advise if I'm overlooking something here as I'm admittedly no central heating expert.
Thanks in advance,
Andy
Check the heating valve is not jammed open,as this sends a feed to the boiler and pump, which will not turn off even if the stat is turned down.
If after taking Garfields advice you still think your cable is damaged I would recommend you fit a new wireless room stat such as Drayton Digistat 1. This will cost more to buy but will eliminate any wiring in walls etc ;)
Thanks guys.
Will check the valve and maybe go with the digistat. Do I assume that will have a transmitter in the airing cupboard and eliminate the need for the wiring??
The reciever will be in the airing cupboard. It will need a live and neutral and the switched live from the heating side of the programmer to your valve as now ;)
