Hello,
I need help trying to figure out how water will travel through a plaster board ceiling so I know which pipes to check or if all floor and landing has to come up. Is it likely to go with the joists or can it go under them? What ever it is its a slow leak and I can't see any evidence of where the water is coming from.
There is a damp area in the middle of my hall ceiling, its been there a while I thought it was a stain until I covered it with smoothover and it bubbled so I scraped it and all plaster and prob years of paint came off back to the bare plaster. I used a moisture tester on it and its over 50%.
It is directly below the doorframe to the bathroom. I managed to get part of a board up. There are no pipes above it, they run around outside edge of room. The joists run left to right when you stand in the doorway. The sink is directly in front of you and the hot water tank is on your right, both have pipes level with the patch but 2-3ft away. Any ideas? Thanks
