- Joined
- 26 Aug 2024
- Messages
- 4
- Reaction score
- 0
- Country
Hello, my name is David. I pulled apart my engine thinking it was a rod knocking. Maybe, it still is. But I haven't found anything yet. I used plastigage to check all rod bearings and only two mains, so far. The clearances are below.
Also , here is the car and engine:
67 Camaro
Bow tie block 454 bored 030 over
12.5:1 trw pistons
Pink dot factory forged rods
Steel forged crank
Big solid roller cam
L88 cast iron heads ported by SIssel
Clutch turbo 400
Ford 9" 5:13 gears with locker, currie axles
Etc
Here are the bearings specs. Also it has water in oil from an intake coolant leak.
I have been looking for the knock with plastigage.
The results surprised me. For a second, I thought is was number 7, but then it normalized the second and third check.
I also read where old plastigage often reads smaller clearance than actual clearance. I wonder if that is the case here, since the clearances were smaller than expected. Here are the results as best as I could:
Rods:
#1 .0015
#2 .0016
#3 .0015 and second time.0016
#4 .0016-.0017 and second time.0014-.0015
#5 .0014-.0015
#6 .0015
#7 first, second, then third, .0017-.0018 then .0014-.0016 then .0014-.0017
#8 .0015
Main bearings (only checked two so far:
1st, about right on .0016
2nd .0015
67 Camaro
12.5:1 trw pistons
Steel forged crank
Clutch turbo 400
Etc
Rods:
#1 .0015
#2 .0016
#5 .0014-.0015
#6 .0015
#8 .0015
2nd .0015
