Hello all,
my first post so please go easy on me...
I have a Firebird Combi 90 boiler, installed about 7 years ago.
Poor me...
Ok the latest issues are that that the central heating pump will not work, and the DHW (Domestic Hot Water?) pump will not STOP working!.
The hot water works just fine.
Here's what I know...
There is constant power to the DHW.
There is NO power supplied to the CH pump under any normal operating conditions - though I have tested it, and when it has power, it pumps water into the radiators as it should.
There is power (240v) to the room stat line in, and when the stat operates it supplies power to the line out and back into the boiler.
The central heating switch is working OK in that it supplies power when operated.
No power is supplied to the flow switch that I can find, though I'm not sure under which conditions it should have power.
When the temperature drops for either hot water supply or CH (when I power up the CH pump) the boiler fires up Ok. Also it cycles OK.
I am thinking that if it was only the DHW pump running constantly then it might be a boiler thermostat pump overrun issue, but with no power being supplied to the CH pump could it be that the relay is knackered?
Although the relay certainly operates when it is supplied with power.
Or is there a PCB hidden somewhere?
Any helpful heating engineers out there with any good ideas?
Poor me...
