Hi All,
I knocked out an old 70s brick fireplace and want to replace it with a new surround and gas fireplace. The photos should click for larger ones.
My house was built in the 50s. The previous fire was gas with a grate that stood directly in the fireback.
Obviously I will let Mr Corgi do all the gas stuff, but I don't have much idea on what i need to reconstruct in order to fit the new fireplace.
Some questions i have in no particular order!
1. Do I need to refit the fireback? Do modern gasfires require them? If so what is the best way to do this? Any special materials required ie fireproof cement/fillers??
2. Should i get a smoke test and or get the chimney swept. Is there any way to tell
3. What about the "throat" and the flue. The previous fireplace fitter had fashioned (badly) some kind of S shape at the top of the fireplace. Which i assume helps the flow of smoke out of the chimney.
4. When should i call the corgi guy in - You can just see the old gas fitting to the right of the pictures. I would guess he needs to come in pretty much before any other work is done, to repair and route the new pipes, then at the end to tidy and reconnect the new appliance?
5. Any recommendations on fireplace shops ( the wife wants a limestone surround), and best ways to refit the hearth and mantel etc. Are there any "plug and play" models out there?
6. Last one, for now , I also need to route some cables across the breach of the fireplace, a TV coax (digital PF100) and a phone cable (for phone/adsl). What would be the best way to do this? I was thinking either increase the small gap between the wall and floor at the base of the fireplace and cement the cables in, or route them completely over the foreplace and chase the walls.
A ton of thanks in advance for any answers
Lee
Lee
