I have failed to get decent pressure from my new shower unit comprising of Grohe thermostatic unit served by gravity fed hot and cold feed; I have pumped the outlet from the therm unit to the shower head, but pressure is not good.
So the question is...................
Can I feed the thermostatic unit with mains cold pressure(maybe reduced by a tap if necessary) and pump the hot water feed/supply with my single input/output pump.(ie pump from the tank to the thermo unit)..if I can somehow regulate the pressure to be approx the same at the hot and cold feed sides of the thermo unit?
I know this may be unconventional, but what problem could I encounter?
Yours in hope
Cheers
Ostin
Yours in hope
Cheers
Ostin
