HELP! Hwo or maintenance oil on newly laid oil floor?
13 Feb 2014
London
I just bought an Emperor Oak Oiled Floor. The salesman of the reseller said it has been oiled 7 times with Woca oil but advises another coat once laid.
Reading on this forum, opinion seems split, (in fact in the past I have found WoodYouLike suggest both options)
it's quite common (these days with so many products coming from China) the "oil" used on pre-finished boards is not really protecting against drips and spillages.
When we install boards like this, we either apply a wax-polish or one coat of HardWaxOil to create a better wear and tear layer.
Why would you want to re-oil a pre-oiled floor straight after installation??
Use a suitable maintenance product 4 weeks after installation and then every 5 -6 months.
Don't re-oil - use a proper maintenance product!
Which one is best for me?
Should I be applying another coat of oil once laid?
Should this be a maintenance oil? Or a normal hardwax oil?
Thank you so much for your help in advance!
Can anyone help? (I'm getting to crunch time)
Thanks!
