help ID roof tile
3 Jan 2012
Down
I recently had a boiler flue pipe removed and have not yet been able to source replacement roof tiles, local builders merchants have none.
The tiles have "B.C.C" and a shield on the underside as can be seen from the images
Houses were built by "Frasher Homes" in Co Down Northern Ireland.
Well it looks like a double roman to me, a lot of companies do there version of a similar profile you may be as well finding something similar and then trimming it with the grinder. but one of the other lads maybe able to put you on to a perfect match good luck.
Hi I wonder if anyone could source these tiles with the marking "BCC Ltd" with a crest again please or tell me where to look for them ?
Only advice I can offer is to give the number in the link a call, see if he's got enough for your needs. let us know how you get on.
