Hi, I have the same problem on my boiler - Ideal EVO C22-35 (previous owner had it installed - can't wait to get it changed!) come on last night.
Cold water wouldn't work for a bit. Went and looked at the boiler and was saying H3. Looked up in the book and this said it was the DHW thermistor issue. Suggestions were to test the resistance to identify if it is an issue with the thermistor or possibly the PCB. My multimeter is at my dads at the mo, but I can get it back at the weekend so can't test it until then.
However, the PCB and the fan were changed in April when the last fault occured (I only moved in in March!); so am thinking this is very likely the DHW Thermistor.
In any case, switched off the boiler and on and the code flashed for a little while, but then it seemed to clear itself and the hot water started working again.
Now the water supply has been funny since we moved in as when you start the hot water on the shower it tends to warm up quickly, run hot for a minute, then go cold for 20-30 seconds, then go hot again. I am wondering if this was linked all along.
Knowing that winter is fast approaching I am a little concerned and thought I would just quickly check if the DHW thermistor is an easy replacement and possible to DIY. I think the relevant part is
this one .
Given the part looks quite simple, am I reight in assuming this looks like it should be an easy change? I'm not boiler technician, but perfectly capable of doing simple jobs - and similarly happy to understand if something is beyond my scope, but would I be right in guessing the process is:
- switch off boiler
- it is in a wet location so switch off the water supply, running out the hot and cold taps to get the water out,
- un plug cable, remove retaining clip, pull out old thermistor
- push in new thermistor (should I silicon grease the o ring), put in new retainer clip and plug in cable
- restart water supply
- restart boiler
All feedback appreciated!
