Hi Guys and Gals,
First post so hi to all.
We have an ideal icos boiler and a water tank upstairs. Last sunday the central heating pump started to make a god almighty noise and got really hot. I switched everything off and isolated all power as we were rushing out. When i got back i built the water pressure back up and switched everything back on. Its still making a faint humming noise.
The hot water is now only getting luke warm despite turning the temp all the way up and having it set to constant.
We have had a few probs over the last few months with radiator valves popping off etc (its a new david wilson home) which weve had to replace olives and tighten everything up. The only problem i can forsee is... is it possible for the heating system to be low on water if so how do i refill it or does it refill itself.
Any help greatly appreciated.
