Hi, i have an Ideal S24 boiler on a honeywell pcb and honeywell timer. System is a good 15 years old.
Worked fine until last week, when the heating and hot water failed, managed to get the central heating running by replacing the Fan and draining system and refilling. Now we have no hot water.
The diverter valve box moves when the mains power switch is turned on, but when you put the heating on to boost or constant it is not firing up and the diverter doesnt move.
Have looked at the pcb and can see a scorch mark near one of the black boxes with a code of 161sed048uhb-t could this be our issue, and if so can i get a replacement and solder or am i looking at a new pcb.
The missus got the water to fire up a short while ago by turning off at the mains and putting water onto constant she let it run for 10mins but when she turned it off and onto the boost setting 'nothing' no movement on diverter, not boiler firing up.
Im at a loss!!
Any help would be appreciated.
Im at a loss!!
