Is anyone able to identify this please? It's a connector used in this application for 28-volt DC, for the purposes of lighting a bulb (I'll actually be stepping it down to 12v and using a 12v bulb but that's probably not relevant at the moment). I need a name for the connector as I want the other half so that I can connect on to it - there isn't really an option to remove the connector unfortunately. It has S64SF stamped into the side of the rear part. Measurements are approximate
Also posted on "Electrics UK" in case any of those guys know what it is...
