My compressor and tools all use fittings like this, with a male connection as shown on one end of the air hose and on the various tools. The other end of the hose has the equivalent female coupling, which has now fallen to pieces. Could anyone confirm the ID of this type of fitting? The bore is just about 7mm, the outside diameter of the narrow part is just under 10mm. Looking at pictures it appears to be PCL "ZF". Does that sound correct?
Also, any suggestions for suppliers at reasonable prices? Ideally I'd like to fit a replacement coupling on the existing hose, but I also wouldn't mind getting a replacement hose with a larger bore.
Thanks, Tony S[/img]
