- Joined
- 16 Nov 2006
- Messages
- 22
- Reaction score
- 0
- Country
My girlfriend is in the middle of a kitchen refit and has uncovered a bit of a mess of a CU installation behind a removed cupboard.
It's what I shall call an "old style" CU with twin blade type modules that look like they used to have rewirable fuses. These have all been retrofitted with MCBs. Tracing back from the CU, there is a bakelite connection block where a second live and earth feed has been taken off and into a mini CU with an RCD (I don't rememeber the spec - maybe 40A / 30mA) and a 32A MCB. This was installed by a proper certified sparky just before Part P landed and feeds her power shower (7.5kW). Going further back, there a the meter and finally a 60A main fuse housed in a greay plastic box.
Now, apparently just after she moved in, she "had an earth installed" by the same guy, and I'm trying to work out what kind it is. Here is what I know:
There is a small earthing block mounted to the board, external to the CU.
There is a conection from the earth block to the CU and from the earth block to the same grey box that the 60A fuse is in.
There is another earth connection that runs from the earthing block, up into the loft and then back down into her bathroom where it dissappears behind some panelling with a load of water pipes and doesn't re-emerge again.
There is a sticker on the board that says "Protective Multiple Earth System Installed".
Now, I'm assuming that since she has overhead power cables (live and neutral only) coming into the house, she had a PME system installed (hence the sticker). However, from browsing these forums, I thought that this required a time-delay RCB on the main feed? Also, does the earth bonding to the water pipes sound right (assuming that's what it is)?
Anyway, the upshot of this is that rightly or wrongly I don't quite trust her sparky at the moment, and I'm urging her to have the whole CU replaced so it would be nice to be able to talk sensibly to someone about what would be required, but I'll come onto that next once the earth thing is sorted out.
