Help identifying roof tile
7 Jan 2010
Yorkshire
I have some broken roof tiles on a kitchen extension, but the tiles have no identifying markings on them. I would like to purchase some replacements.
Can anyone please identify these tiles from the attached photos. They were installed about 9 years ago and the lower corners have been snapped. If I can't find replacements I did wonder if I could somehow glue the corners back on!
... also FYI, most of the extension roof is fitted with these narrower versions of the tile and the wide ones are being used in certain places only, such as upto the velux. Not sure if this helps identify them. Typically, I have lots of spares of the smaller tile!
Sandtoft 20 20 , tile and half verge tile is what you have in the picture .
The standard tile is just called a sandtoft 20 20
Thanks, that does look like the one. I guess this is the "left hand" version as the left hand side is "flat" while the right hand side is not as thick and designed to sit over the tile to the right if it.
It would appear all 3 broken tiles are in similar positions and broken on the same corner.
