We have just installed the above and have a problem with tamper lock out, the set up comprises of the main panel connected to a LCD keypad, we have just 2 pir's and an outside bell box, when we power up we put the default user code in and the alarm stops then the display shows tamper lock out, if you put 9999 engineers mode
then. Do a walk test all the zones show up number 1 to show they have been broken.
now i think that there should be links put into the unused zones within the panel, can anyone confirm?[/b]
