Morning all, I would appreciate some advice on attaching U channels of new shower cubicle to wall.
I've just replaced rotted ply with Aqua panel on to 2 wall studded walls. Tiled, grouted and all looking good. I'm just starting to fit new glass enclosure that has a U channel on each panel to attach to wall and slot glass panel into.
However on one wall any form of mechanical fixing will go through porcelain tile, through aqua panel and then have nothing to bite into. Will I be OK with dry wall fixings, ie something that expands out behind panels etc, or dare I use some form of adhesive.
The other panel will be very secure as I fitted addition battens to screw into behind aqua panel. On the other wall I will unfortunately miss anything structural with my screws!!! aargh.
Will dry wall fixings be strong enough, and I will be going through a depth of 10mm tile, 3mmmm adhesive, 12mm aqua panel, so Im curious as to which fixings to use that can reach that depth but without being too large in diameter.
Any suggestions appreciate.
H.
H.
