Hi
As (almost) the final part of my bathroom make-over, I'm ready to install the new w/c. However, when I slide the pan's outlet into the rubber seal on the soil pipe, the pan sits out too far from the wall (well actually, it's the cistern that's too far out, but you know what I mean).
My dilemma can be seen in this picture.
What's the solution? As the picture shows, the soil pipe comes through the floor and is attached to a bend which houses the rubber ('finned') seal. Even pushing the w/c outlet right into this seal leaves the w/c about 25mm too far away from the wall top be secured.
Thanks in advance
EDIT - I've just found this product online - is this the easiest solution? I've never seen a w/c with a flexi fitting before - are they ok to use?
Thanks in advance
