help - leaking gate valve in airing cupboard
17 Jan 2004
The red gate valve (in the airing cupboard) on the cold water feed into my loft is dripping ... I've had this valve turned off tonight while I fitted new bathroom taps, so that's what's done it ... :oops:
It's not leaking enough to cause chaos, but it is going to be a mess by the morning if I can't sort it tonight. The drip gets worse if I close the valve (why is that?)
Is there anything obvious I can do (aside from turning off the water) to stop this? Are these valves repairable, or will I need to replace it? It's in a really awkward place! :rolleyes:
In all probability all you need to do is slightly tighten the gland nut.
Just under the wheel head is a small nut which compresses some packing material against the shaft.
One minute then happy dreams!
Tony Glazier
Fantastic - job done - thank you very much!
What a great forum :D
Well at least one person here appreciates me!
Some others dont!
Just getting a call from a potential customer at 11 pm. Should I answer?
Tony Glazier
agile...ur an hour out...or do u live on the continent ?
