We have a leaking pipe leading from the water main on our property.
We can access the main switch off valve.
We have dug some deep holes trying to locate the leak some of these 4ft deep and have only succeeded in locating the point the water comes in to the house.
We have not found the leak and even if we do we are not going to be able to change the pipe this deep.
We believe we have found a blue pipe which appears to feed the water valve point but is coming from another direction so not likely to be associated with our house.
How easy is it to put a new water main pipe in and do you have any advice on how we can undertake this without expensive cost of bringing in the water contractors.
I mean we have done most of the hard work dug to depth, I begrudge paying money to them now.
We are desperate for your advice please help..
cat xx
cat xx
