I have a stelgrad boiler and use a summer valve. This morning I used the summer valve to use my radiators and they have only been lukewarm all day and the "hot" water from the taps is lukewarm only. Any ideas??
Yes it is a gate valve so that the radiatiors don't come on in the summer. I have turned the correct valve but the problem has existed since doing that. prior to that the hot water was fine.
